10-26-2005 04:37 AM
10-26-2005 05:07 PM
Hello:
1. I'm sorry to say that I do not have an answer for this one.
2. Here is some info about IVI-C and NI:
The important point to note here is that the two implementations are designed to be complimentary, and to coexist peacefully on the same system. Neither of the two implementations is going away. Also, neither implementation is preferred over the other in all situations. Obviously there are cases when one is better than the other, but it is definitely not a blanket rule. For example, if you are programming in Visual Basic, an IVI driver with a COM interface is easier to use. However, if you prefer to program in LabWindows/CVI then a C interface is more native to your environment and is easier to use. There are also other environments, such as LabVIEW or Visual C++, where neither implementation is 100% ideal. In those cases, the IVI Foundation specifications leave room open for vendors to support those environments with native wrappers (LV VIs or C++ classes).
NI currently has tools built on the C architecture that you can use to build systems based on IVI. In the future, as the specifications evolve, NI's tools will follow to ensure that end-user systems work without any interruptions. Also, our IDNet web site is open for submissions, so we hope that other vendors will submit their drivers to be distributed from our web site. As for the class drivers, they can be written to call COM or C specific driver.
Emilie S.
10-27-2005 10:33 AM
