write a sequence of frequency to agilent 33522a
Hello everyone ,
I' am using Agilent 33522A , Labview 2010 , windows 8 and an USB - GPIB cable 82357B to communicate with my instrument.
I've downloade my instrument driver ( Agilent 33522A series examples)
This my first project using labview so I'm facing some difficulties.
I want to make a sequence of 10 frequencies (the user will write them everytime he uses the application) that the instrument will read one by one with a delay time of secs.
here what I've done but I'm not sure where should I put my while  loop.
Please any help ?
Thank you so much 🙂
(4,084 Views)
hello again
here what I decided to do but still blocked though.
I have a numeric array (that user shall fill with frequencies he wants to show on the instrument Agilent 33522A)
I added an array subset and a subarray to read a value each time.
Now I want to put that value in the frequency in order to configure my instrument.
Here is a screenshot to explain more what I tend to do
I'd really appreciate any help
thank you 🙂
(4,063 Views)
build up the array and use automatic indexing instead of having the array outside the while loop.
further push the clean up your diagram butto to align most of the wires.,
greetings from the Netherlands
(3,999 Views)
thank you so much !!!! but I've already solved the problem 😄
(3,996 Views)
