write digital and analog to TDMS
Hi i have a PCIe6351 and try to read a digital port starting with a trigger and when an analog trigger is activated acquire an analog data
is there a way to do this and write it to a TDMS single file
in general that's what i need but for now i cant write digital to TDMS when i try it the program collapse without an error message
(3,872 Views)
Please post this to the DAQ board,
greetings from the Netherlands
(3,854 Views)
Accepted by topic author Baku2187
Each channel in a TDMS file can be of a different data type.  What do you mean "the program collapses"?  Have you tried to write to different groups in the file?
If the data doesn't need to be written to the file at the same time (that is, if the data is sequentially written to the file), you can actually do this with the integrated TDMS logging feature in DAQmx: http://zone.ni.com/devzone/cda/tut/p/id/9574
Andy McRorie
NI R&D
(3,821 Views)
Thanks this is what i need
(3,815 Views)
