wt210 serial comminication cable for laptop
Hi I am new to WT210 power meter, I want to connect it to a laptop that has DB15 serial interface. What options to I have?, I mean what cable should I use
Message 1 of 10
(5,925 Views)
Laptops don't generally have a DB15 serial connection. The DB15 is usually a video connection. Device manager will tell you if you have any RS232 ports.
p.s. What is a WT210? Who makes it?
Message 2 of 10
(5,923 Views)
Yokogawa makes the WT210:
http://tmi.yokogawa.com/products/digital-power-analyzers/digital-power-analyzers/wt210wt230-digital-...#
-AK2DM
Message 3 of 10
(5,913 Views)
Basically, the wt210 allows communication with a laptop via 25 pin serial connection. I am using an acer travelmate laptop (i think it doesnt have serial ports). Some article suggects I use a USB-to-serial conveter and 9 pin female to 25 pin male adapter cable.
Message 4 of 10
(5,886 Views)
As I said, windows device manager will tell you if you have any serial ports. If you don't, then a USB-RS232 adapter is the obvious choice.
Message 5 of 10
(5,878 Views)
jerezar,
The type of cable to use will depend on the 'Handshaking Method' you configure the WT210 to use.  There is an entire section in the manual devoted to configuring the WT210 for serial communication.
Message 6 of 10
(5,874 Views)
OK , let me get this straight. I will get as db9 female to db25 male connector and USB-to-serial converter with db9 male on the serial end
Message 7 of 10
(5,811 Views)
Hello jerezar,
If you are trying to get to a db25 connection from your laptop and do not have a serial port on your computer you can use the USB to serial and then a db9 to db25 connector. Have a great day!
Best Regards,
Adam G
Message 8 of 10
(5,776 Views)
Hi Adams,
I am facing difficulty to download Labview 7.1 drivers for Yokogawa WT210 Power analyzer from the NI site. Requesting you to attach the same.
Rgds
Ajith
Message 9 of 10
(5,707 Views)
If you can't download it from one NI location, not sure why you would be able to download from another NI location but here it is.
Message 10 of 10
(5,681 Views)
