yellow exclamation mark
I finally managed to get my MAX working.
Have another problem now.
When I expand the VXI System tree, I have a yellow exclamation mark on Frame 239. I have attached a pic for further reference.
Any help will be appreciated.
vxiguy
(4,294 Views)
MAX is pretty smart. If you click on that line and read what is on the right side what does it say?
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,285 Views)
Hi GovBob,
When I right click on it and click on properties, I get the following message.
1) Not all of the device functionality may be available.
2)  There is no VXI slot 0 device in this frame. This is assumed to be a VME frame.
I am not understanding these messages, as I have a VME-MXI-2 controller in the chassis on slot-0
vxiguy
(4,254 Views)
Hi vxi_guy,
Have you run the Resman algorithm? If so does it return an error? Also, your first post seems to reference another thread you had. Can you provide a link?
Matt
(4,220 Views)
