InstrumentStudio
How to set source for a virtual DMM in Instrument Studio
Please see attached picture:
In Ni MAX I added a simulated NI 4070 DMM.
After viewing this virtual DMM in Instrumentstudio the DMM always shows 150 Volt DC.
How can I change this value?
Or set a another source?
Thank you in advance,
Klaus
(2,739 Views)
Klaus,
Currently, simulated NI-DMM instruments will always return a value around half the selected range (plus some simulated noise) when measuring/fetching measurements. There is no way to change the output value or the source.
I am curious what you expected, and how big an inconvenience this is for you. Could you provide some details as to your use case?
Tobias
Principal Software Engineer
Driver Software
(2,683 Views)
