InstrumentStudio
RFmx in InstrumentStudio
Is RFmx included in InstrumentStudio? If so, is there any specific reason to access it from InstrumentStudio instead of on its own?
(2,322 Views)
The interactive RFmx soft front panels are hosted in InstrumentStudio (starting late 2022); however, most RFmx personalities (5G NR, WLAN, Bluetooth, etc.) require an RFmx license that is not included with InstrumentStudio. If you have a license for a specific RFmx personality like RFmx NR, that license allows you to create your own program using the API or interactively setup and acquire a measurement using InstrumentStudio.
Jake H | Product Manager
(2,285 Views)
Thanks for the response. If I have a license for RFmx NR for instance, can I access it through InstrumentStudio as well? Or do I need to get another one?
(2,273 Views)
No problem. The license for RFmx NR allows you to use both the NR API and NR soft front panels within InstrumentStudio. You will not need another license to use RFmx NR interactively in InstrumentStudio.
(2,264 Views)
Thanks. If I can get the same functionality (API as well as soft panel buttons) via RFmx NR, is there a reason to use it via InstrumentStudio?
(2,257 Views)
