JDP Science Tools
JSONtext: JSON Schema?
James,
I didn't find out "Generate JSON Schema from LV Datatype" at JSONtext library as below. Can you please share where we are able to download it?
Message 21 of 31
(3,449 Views)
I think there is no generate Schema from Labview date type functionality yet in JSONtext.
I'm currently working on one and will try  release a package soon.
Message 22 of 31
(3,444 Views)
I've needed this too and have made some progress. Would be happy to share/collaborate.
Message 23 of 31
(3,388 Views)
I've created a working repo here: https://github.com/JKISoftware/generate-json-schema-labview
Note that the code is quite simple (not much more complicated than what you're looking at below)
Message 24 of 31
(3,383 Views)
Hi Jim,
Is the repo public?
I can't find it on GitHub..
Cheers
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 25 of 31
(3,370 Views)
Hi Jim,
I have made some more progress and could make the repo now public: novatron-fusion/LabVIEW-JSON-Schema-Generator (github.com)
Please have a look! I would be glad for any feedback.
Message 26 of 31
(3,333 Views)
I've also now added a simple Schema Generator to the package:
Message 27 of 31
(3,123 Views)
Hi guys,
I am not very savvy with JSON formats, and I would like to use the 'Validate Against JSON Schema.vi' to show user where a mistake is:
How would I infer the JSON Schema from an already existing JSON file?
I am confused as to how to format the JSON Schema input of the above VI.
Would anyone be able to help me out, please?
Below is an example JSON file content:
Spoiler
   "Recipe":{
      "UART_Ports":[
            "Device_Name":"UART1",
            "Comm_Name":"UART1",
            "Serial Settings":{
               "timeout(ms)":1000,
               "baud rate":19200,
               "data bits":8,
               "parity":0,
               "stop bits(10;15;20)":10,
               "flow control":0
            "Device_Name":"UART2",
            "Comm_Name":"UART2",
            "Serial Settings":{
               "timeout(ms)":1000,
               "baud rate":19200,
               "data bits":8,
               "parity":0,
               "flow control":0
      "DAQ_config":{
         "Digital_Inputs":[
               "Alias":"Bon_Down",
               "Channel_Address":"cDAQ1Mod1_NI9375/port0/line11"
               "Alias":"Air_Pressure_OK",
               "Channel_Address":"cDAQ1Mod1_NI9375/port0/line14"
         "Digital_Outputs":[
               "Alias":"Close_Canopy",
               "Channel_Address":"cDAQ1Mod1_NI9375/port1/line0"
               "Alias":"BON_Up",
               "Channel_Address":"cDAQ1Mod1_NI9375/port1/line3"
         "Analog_Inputs":[
         "Analog_Outputs":[
      "Test steps":[
            "retests":0,
            "continue on failure":false,
            "Log results":true,
            "Test_name":"step1",
            "Enable":true
            "retests":0,
            "Log results":true,
            "Test_name":"step2",
            "Enable":true
      "UUT_Spec_Limits":[
      "General Info":{
         "Model Name":"modelName",
         "Event Logger":false
      "DataBase_Config":{
         "Enable DB":true,
         "Results Table Name":"tbl_name"
      "Execution_Config":{
         "Stop On First Fail":true,
         "Nr of Repeat":0,
         "Repeat Sequence":false,
         "Sleep before repeat":0
      "Process_Conditions":{
         "Start_Conditions":[
               "Channel Alias":"Air_Pressure_OK",
               "Expected State":true
               "Channel Alias":"E_Stop_OK",
         "Test_Running_Conditions":[
         "Stop_Conditions":[
         "Abort_Conditions":[
               "Channel Alias":"STOP_Signal",
               "Expected State":false
   "Project_Specific":{
      "Product Config":{
         "Product SKU":"",
         "...Technician Entry...":""
      "Station Config":{
         "Station Option (eg. DB)":"",
         "Station Option (eg. ID)":"",
         "...Engineer Entry...":"",
         "BarcodeLength":23,
         "BarcodeDashNumberPresent":false,
         "UserIdMajorMinorBuild":"0.0.14"
      "Move_To_TFW_PC":{
         "TCP/IP Present":false,
         "Use_Limits_Database":true
      "CW Mask Limits":[
            0,
            -78
            460,
            -78
      "CM Mask Limits":[
            0,
            -77
            460,
            -77
Message 28 of 31
(2,020 Views)
There is a generate schema function in the library that should make a basic schema from your JSON.
Message 29 of 31
(2,009 Views)
Thanks, wasn't aware of that function, I'll give it a go.
Message 30 of 31
(2,001 Views)
