JDP Science Tools
SQLite Views
I have created a View in SQLite Studio for my SQ Lite database.  In that tool, I can query the table without issue.  I am using the SQLite Library v1.16.0.115 to interact with the database via LabVIEW.  When I use the LabVIEW toolkit and attempt to query the table, I receive error 402860 stating that the table (i.e. my View) does not exist.
Query:  SELECT *
             FROM MyVIew
             LIMIT 1".
I am using the SQLite .dll version 3.51 on Windows 11.  Can LabVIEW be used with the SQLite Library to interact with database Views and if so, how?
(1,834 Views)
Accepted by topic author JFrost
I use views all the time.  Are you sure you haven't created a Temporary view?
(1,824 Views)
I developed the  project on notebook(win11,labview2020), I tested  query data, insert data and  delete data,all are fine;
I copy the project fold(include the same DB file) to another PC(win10,labview2020),Query data is fine ,but cannot insert data and delete data,report SQLITE_ERROR(1).
How to change the configuration of PC?
(1,798 Views)
@drjdpowell , I think that you were right.  I must have had a temporary table.  I created a new view again, and this time I was successful to accessing it via the SQLite library.  Thank you.
(1,740 Views)
