JDP Science Tools
postgreSQL library
As mentioned on LAVA
I will soon be posting a new version of @drjdpowell 's PQ LabVIEW library.
This library is based on external libraries, we use it on Windows, Ubuntu and NI Linux RT.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,655 Views)
Hi
Thank you for your work!
If a comma is used as a separator, an error occurs.
In order to avoid this, you must force a period as a separator.
In VI's:
***\PostgreSQL Library\Connection\Single Command with parameters.vi
***\PostgreSQL Library\Result\Get Column DBL.vi
***\PostgreSQL Library\Result\Get Column Timestamp.vi
(4,342 Views)
@TiTou you might want to swap in the Time functions from JDP Science Common Utilities, as they are improved on these (and don't have this bug).
(4,324 Views)
Thank you I'll look into this
Epictetus
Antoine Chalons
(4,309 Views)
