JKI State Machine Objects
Adding a Splash Screen to your Application using the SMO Framework
In this short video, you will learn how to use the templates provided by the SMO Framework in order to easily add a splash screen to your application. Make sure to install the latest version of the SMO framework and the SMO Templates (Basics) using VIPM.
Javier Ruiz - Partner at JKI
jki.net
vipm.io
Message 1 of 1
(6,247 Views)
