JKI State Machine Objects
SMO Timed-Loop Template
Check the new SMO Timed-Loop template. This template modifies the Process.vi method to use a Timed Loop + Event Loop instead of the traditional JKI State Machine. This pattern can be imitated in order to add any design pattern to an SMO class.
Enjoy!
Javier Ruiz - Partner at JKI
jki.net
vipm.io
Message 1 of 1
(5,849 Views)
