JKI State Machine Objects
Webinar: Creating a Hardware Abstraction Layer using the SMO Framework
Make sure to check Francois Normandin's webinar on how to create Hardware Abstraction Layers (HAL) in LabVIEW using the JKI SMO framework.
You’ll learn:
- What is Hardware Abstraction
- What makes Hardware Abstraction useful
- How to create a simple HAL
- How a HAL can help you create maintainable and testable software
The source code for the webinar is available here.
We hope you enjoy it!
Javier Ruiz - Partner at JKI
jki.net
vipm.io
Message 1 of 1
(5,910 Views)
