02-02-2016 12:06 PM
Take a look at our latest blog post to learn some of the basics about the framework, including a short video on how to create your first SMO class.
.jpg)
08-09-2016 05:15 AM
I am still at the beginning to understand the concept of the framework and I think I did not catch the idea behind it completely. What is the reason behind the converting from object to reference number than to ref of cluster and back to object ?.
08-09-2016 11:24 AM
Hi jeornheit,
Thanks for the comment. This is a good questions when it comes to ByReference SMOs. Using a reference number instead of directly the DVR on the private data allows for faster edit-time performance. The only caveat is that we had to add the Ref to DVR and DVR to Ref methods wrapping the in place structure that accesses the DVR's data (as shown below).
I hope that helps!
08-12-2016 05:47 AM
Hi all!
There is a thing wich is or missing, or I am too bad at finding it.
You provide number of templates, which differ severly in functionality. However, I cannot find practical description of whea actually they do.
E.g. If I wouldn't read the post about dependency insertion, I would have no clue that "Instrument" template allows for such thing.
Is there any documentation, or plan for cerating one, which describes those "hidden" (i.e. not avaliable through SMO editor) features?
04-23-2019 05:20 AM
@_Mike_ wrote:
Hi all!
+1.
It'ss been 3 years since this comment. Is there any documentation available?
Lack of real documentation about JKI SMO is really not helping me adopt it. I have a CLD for quite some time now, but I guest I'm not smart enough to just guess how the SMO works, how templates differ, etc.
Even the HAL webinar video skips over some of the more detailed aspects and does not explain why he chose the Instrument template for microscope, and ByRefWithEvent for XYstage and Camera.
11-19-2019 02:39 AM
+1 and 7 month. It looks like for us there is no way to use SMO's (despite that according to HAL webinar this is exactly a thing that we need). No documentation, and even an example from HAL webinar is impossible to run with the latest JKI framework.
11-19-2019 05:14 AM
Check this discussion : https://forums.ni.com/t5/JKI-State-Machine-Objects/JKI-SMO-vs-Actor-Framework/gpm-p/3992000#M123
Francois acknowledges the lack of doc and vows to make videos
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
11-25-2019 03:35 PM
@D_mitriy, can you tell me what is missing to make the example code run? If there is a backwards compatibility issue, I would like to fix it. (Have you applied the VI package configuration before loading the project?)
09-08-2020 09:54 PM
The problem that I found was that the events in the event structure was broken. I think the state machine editor had something to do with it.
What I did was disconnected the wires in the Register Events case and then shorten and unshorten the user event register vi..
Going back into the idle case I had to reassign events to the event structure that was broken.
Next, I had to fix the Dictionary SMO. I think it was a similar problem. I don't remember exactly off the top of my head.
