JSON Toolkit for LabVIEW
Error connecting to GPIB driver or device.
I am not able to use toolkit due to the attached error. It says it's due to NI 488.2 driver. But I have tried to switch to 17.6, 18.5 and 19.0 of the driver, I still get the same issue. The error is reported on Parse JSON.vi
(6,447 Views)
in this way it is very hard to understand... if your code is very big, may you attach the section that generates the error?
(6,431 Views)
Hi TengWu,
Unfortunately the error reporting in the i3-json library can be misleading. The library uses error code zero for all errors. The important part of the error is the message "String parsing fail: Bad escape char".
This occurs if you have a string in your JSON with an invalid escape character. For example the following JSON:
["string one", "string two", "invalid \? escape character"]
The third string in the array has the character sequence \? which is invalid in a JSON string. The valid escape character sequences can be seen in the string section on http://www.json.org/ reproduced as follows:string.gif
So valid character escape sequences in a string are \", \\, \/, \b, \f, \n, \r, \t or \uXXXX where XXXX is 4 hexadecimal digits
To make the above JSON valid we have to escape the \ character as \\ which can be seen in the following:
["string one", "string two", "invalid \\? escape character"]
You may want to use a JSON validator to ensure your JSON is valid. You can search online for a JSON validator to test your use case.
Milan
(6,402 Views)
To be successful, you need to use the secure link
https://api.openweathermap.org/data/2.5/weather?zip= .
Also, you need to create your own  free API key on the website https://home.openweathermap.org.
It is not at all a GPIB or VISA related error. :-))
(5,535 Views)
