JSON Toolkit for LabVIEW
Is this the same toolkit which Aristos Queue created?
Is this the same toolkit as https://decibel.ni.com/content/docs/DOC-24015 ?
Ritesh
(11,896 Views)
Hey Ritesh,
Old question but, in-case anyone is searching, the i3 JSON toolkit is a bit different from the AQ Character Lineator.
If you want to serialize and de-serialize LabVIEW Classes (.lvclass) representations of data then the AQ Character Lineator may be better suited for the task.The AQ Character Lineator is also being piloted as part of the Community Source of NI Code project where NI R&D and the community work together to add features and improve different G libraries.
If you want to parse general purpose JSON data then the i3 JSON Toolkit from this community or the LAVAG JSON LabVIEW toolkit may be helpful.
Finally starting in LabVIEW 2013 there are now JSON Decoding and JSON Encoding primitives right on the palette.
Best,
Milan
Milan
(9,871 Views)
