JSON Toolkit for LabVIEW
License of JSON toolkit?
Hi All,
very nice framework! Thanks a lot for sharing. My question - what is the license of this toolkit? Can it be used in commercial projects as well? I found the licence to be "i3-labview" - "There are no declared licenses for this project."
Thanks for your help and greetings,
Chris
(11,564 Views)
Hi Chris!
That is a great question. I based my parser code off of the one by Patrick van Bergen on the Procurios blog How do I write my own parser? (for JSON) because it looked very clean and translated well to LabVIEW. Patrick's code was MIT Licensed which is very permissive and allows sublicensing, etc, so I think I will do the same for i3-JSON.
i3-Twitter and i3-OAuth will be BSD 3-clause because they use components from OpenG and BSD 3-clause seems to be the OpenG license of choice. BSD 3-clause is still very permissive, and as far as I can tell compatible with the MIT License so I don't really expect any problems there.
I'll make sure to update the packages to reflect this in the next release and let me know if you have any other suggestions!
Milan
(7,520 Views)
