LabVIEW 2021 Public Beta
Composite OR error weirdness
This used to work in LV18, now in LV20 (and 21 beta) this brakes in some situations:
I'm sure there's some logic behind it, but AFAIC, it should just work...
The error in\error out + OR is the simplest situation where it breaks, even in a new VI.
The problem is only there for 1 input. Extracting the node unbreaks the wire.
Message 1 of 8
(4,578 Views)
Could it be related to this issue discussed on LAVA that resulted in bug ID 1289111 ?
LabVIEW is not correctly determining when it needs to recompile/save the VI when switching between RT and Windows
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 8
(4,533 Views)
That LAVA content is hidden (from me).
But there's no RT involved at all.
Message 3 of 8
(4,528 Views)
This was posted publicly a little while ago where it was ignored, and then forgotten by the author (me).  No CAR or bug was assigned.
Message 4 of 8
(4,520 Views)
It shows once you log in. (Not sure why Lava is configured that way, but it will prevent finding it using a google search 😞 )
I agree that's quite a different problem. (At first glance it resembles this report, but probably not the same cause)
Message 5 of 8
(4,509 Views)
Let's hope it gets some attention now...
Message 6 of 8
(4,500 Views)
Almost certainly related to the feature which is supposed to break wire branches instead of the entire wire.
Message 7 of 8
(4,488 Views)
I've created Bug 1518595 to track this issue.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 8 of 8
(4,482 Views)
