LabVIEW APIs Discussions
How to write on LabView shared variables with MATLAB
I have a test bench that uses Labview shared variables as an API and is connected via Ethernet to my host pc. The whole processing takes place in MATLAB/Simulink and I only want to write the final Settings into the shared variables of Labview. Is there any way, to write the values in real time without using Labview?
there is a test API written in Labview that works.
we also have the NI DAQ available. It is possible to connect the test bench with the DAQ.
 I expect the project of Labview to be written in Labview 2013 and I need to use MATLAB 2013.
I am completely new to Labview. Maybe I need another tool?
best regards
Message 1 of 1
(3,941 Views)
