LabVIEW APIs Discussions
Undo for BD cleanup method
I have found the BD cleanup method to be invaluable with scripting.  Just drop everything and clean up at the end.  Now I have a case where I am modifying existing code and along the way I end up with a few broken wires and some kinks.  A quick BD cleanup is usually very effective.  However, I would very much like the ability to Undo the changes at the end if I don't like the results, and the BD cleanup method seems to wipe out undo transactions.  I can place begin/end transaction around the BD cleanup and still no luck.  Any workarounds, or am I missing something.  Same behavior with remove bad wires, at least this is easily worked around with a little traversal.  I thought that saving and reverting might work, but saving also seems to take out the undo buffer.
(4,010 Views)
tst  pointed out on the LV discussion forum that calling the CleanUp method on Diag.TopLvlDiag is undoable.  Excellent.
(3,217 Views)
