LabVIEW APIs Discussions
VI Scripting in LabVIEW 2012: change font size of tab control page label (description)?
Hi all,
I use LabVIEW 2012 with VI Scripting and need to set the font size of the tab control page labels (descriptions).
It is possible to set the font of the tab control label but I couldn't find any possibility to do this for the tab control page labels (descriptions).
I hope you can help in this case. I need to do it programmatically!
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(7,282 Views)
Hi Suse,
as a NI employee  you could ask such questions internally - and then provide an answer to us too…
(5,872 Views)
Hi Gerd,
I am no more a NI employee so this is why I ask!
(5,872 Views)
Ok, so you now created a thread in the LabVIEW forum too?
(5,872 Views)
yes because I thought I won't get an answer here.
(5,872 Views)
Even when you can't wait for atleast a day you should always provide links when you create double posts!
(5,872 Views)
yes you're right. makes sense. now the forum's post is linked above. hopefully there is an answer.
(5,872 Views)
