07-15-2009 10:04 AM
If there is a property or method that you'd like to have access to, please post your wish here.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
07-15-2009 10:05 AM
I wish the case sensitiveness on case structure was exposed ![]()
Epictetus
07-15-2009 10:07 AM
I wish frame colour for all type of structure was exposed. When I change case sensitiveness on a case structure I usually like to change the frame colour as a reminder ![]()
Epictetus
07-15-2009 10:08 AM
I wish the inline VI method was accessible.
Epictetus
07-15-2009 10:45 AM
I wish that it were possible to place a structure around a group of objects (instead of just placing an empty structure, which is all you can do now), like the user can when they place a structure with the mouse.
07-15-2009 01:59 PM
... and, by extension, he wishes that it worked in many of the cases that you might want it to work for...
07-15-2009 01:59 PM
Application:Menu Launch:App
Application:Menu Launch:VI
Needed if you want to create utilities to put in the Tools menu.
07-15-2009 02:01 PM
I wish there was a method that returned a VI's run-time menu ref. You can get the RTMenu path, but not the ref.
07-15-2009 02:15 PM
I just wanted to chime in and say that:
1) I'm responsible for continuing development on LabVIEW Scripting.
and
2) I'm following this thread.
I can't promise that everything you ask for will make it into the next release of LabVIEW, but I can promise that everything you ask for was considered.
Keep the wishes rolling in!
07-15-2009 02:29 PM
Maybe more of a project api wish than strictly scripting, but I wish the way to set the default palette for a library was more obvious...
