LabVIEW APIs Discussions
create a type def from a cluster control
Hi all
Is there a way to create a Type def from a cluster and save this to a hard drive so that I can use it it in different VI's
Jürgen
(10,371 Views)
This RCF plugin demonstrates how to convert a cluster to a typedef (but doesn't save it) - http://decibel.ni.com/content/docs/DOC-5812 .
This one demonstrates creating and saving a typedef - http://decibel.ni.com/content/docs/DOC-5813
___________________
Try to take over the world!
(6,348 Views)
Jürgen,
right-klick the cluster and select /Advanced/Customize/. The cluster is opened in the control editor where you can safe it as as control, a type-def or a strict type-def. Strict type-def's define not only the type of control, but also its optics, whereever needed.
HTH!
Uwe
(6,348 Views)
Thanks for your help
I think I found the solution thanks tst
Jürgen
(6,348 Views)
