LabVIEW APIs Discussions
creating ring and path controls
I have a little project with LabVIEW Scripting: reading a pseudocode datatype (similar to that shown in context help) and turning it back into a LabVIEW datatype.
Unfortunately, I haven't been able to support ring or path datatypes, because I can't find the "path control" value to wire to the "style" terminal of "New VI Object".
If there are any workarounds, I'd love to know.  If you have any comments, that would be great also.
The reason this VI was created was to aid parallel development in LabVIEW, C++, and Java for an Autonomous Development Kit for the F.I.R.S.T. Robotics Competition.  I'm hoping that, since these C++ and Java programmers have no experience with LabVIEW (for the most part), this pseudocode will be an effective way to communicate datatypes.
Marshal Horn
(4,131 Views)
The element in the that ring has the same name which appears in the palette, in your case "File Path Control" and "Menu Ring".
___________________
Try to take over the world!
(3,426 Views)
Thank you.
Marshal Horn
(3,426 Views)
