LabVIEW APIs Discussions
disable a daq
hi to all,
i have 2 daqs in the same application,
how i can disable a daq when the 2nd start to read data?
Message 1 of 15
(8,800 Views)
Could you specifiy your problem a little more accurate?
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 2 of 15
(6,767 Views)
in my vi i have a daq and a jump button which call another vi which contain the second daq
when i run the the first vi and i press on jump button ,an error occur :
                                     "Error -50103 occured at DAQmx control task.vi
                                        possible reason :
                                       the specified resource is reserved.the operation could not be completed as specified "
how i can disable the first daqmx before pressing the jump button?
Message 3 of 15
(6,767 Views)
If you can post your VI or a Snippet of your code, ( if it is possible ) that would be useful.
Anyway, if you want to prevent the user to press your "jump" button, use Disabled property of the control. (Right Click - Create - Property Node - Disabled ). Set Disabled & Grayed out value to the Disabled property so the button can not be pressed. If you want to enable this control again, just set the Enabled value to the same property.
I hope it helps,
[Hungary]
Message 4 of 15
(6,767 Views)
old stabilometre.vi is the main vi ,
in the part "reeducation" when i press stabiliser button which is jump button,it must call stabiliser.vi
Message 5 of 15
(6,767 Views)
Your JumpButton is an XControl.
Please post it with all subvis.
[Hungary]
Message 6 of 15
(6,767 Views)
I think the problem could be the following:
  • Your top level diagram has a DAQ call. I would suggest to use DAQmx StopTask.vi and DAQmx Clear Task when it is done. Do the same when your stabilizer.vi DAQ Call finished.
  • In the stabilizer.vi the Loop never ends. If you want to use this VI as a SubVI, take care of stopping the loop.
[Hungary]
Message 7 of 15
(6,767 Views)
i don't understand
where i would put  DAQmx Clear task  and DAQmx Stop task in old stabilometre.vi?
Message 8 of 15
(6,767 Views)
If your Stabiliser.vi is a dialog - type subvi, Use STOP button to finish the execution of the Stabiliser.vi. I hope this helps!
[Hungary]
Message 9 of 15
(6,767 Views)
stabiliser.vi is not a sub vi
Message 10 of 15
(6,767 Views)
