LabVIEW APIs Discussions
what style for tunnel object class?
I amusing LabView scripting to create and populate a case structure.  It is nearly done.  Each case is populated with the code I want.  My final step is to make a tunnel on the case structure.
I go to create a new VI object and select the Tunnel object class.  However, I have no idea what 'style' to select from the long list of objects (no, tunnel is not one of the options).  Any help?
(7,057 Views)
I don't know the answer to your question, but I do know something.  You can create a temporary node outside the Case structure, wire from inside the Case structure to the temporary node and then delete the temporary node.
...makes this:
Jim
(4,123 Views)
More information here - http://forums.ni.com/t5/LabVIEW/Programmatically-creating-a-tunnel-with-LV-scripting/td-p/1830745
Jim
(4,123 Views)
