Hi All
I have developed Utility which worked like Windows hyper terminal utility.
HyperTerminal is a program that you can use to connect to other computers, devices and host computers.
HyperTerminal has capabilities beyond making connections to other computers and devices. It can, for example, transfer large files from a computer onto your portable computer using a serial port rather than requiring you to set up your portable computer on a network. It can help debug source code from a remote terminal. It can also communicate with many older, character-based computers.
HyperTerminal records the messages passed to and from the computer on the other end of your connection. It can therefore serve as a valuable troubleshooting tool when setting up and using your serial port. To make sure that your device is connected properly or to view your device settings, you can send commands through HyperTerminal and check the results. HyperTerminal also has scroll functionality that enables you to view received text that has scrolled off the screen.
Also Developed for to test the serial port
Zip file includes exe
Save to file option is added
Please Give your comments
Prabhakant
Any suggetions ???? ![]()
Hi
A real LabVIEW implementation of Hyperterminal is a long missing feature, so that is very good.
I would like it to be this program available in two forms in which one is as basic as possible to function also as an example.
But then it needs more comments in the coding and all terminal labels visible.
First an irritating question: Why did you recolor all basic elements in the blockdiagram, it makes it less readable.
One of the differences between LabVIEW(VISA) and Hyperterminal is the speed in which characters are sent out.
Hyperterminal is definetely slower and for some devices a char by char output is necessary. This could be added.
But I'm glad you had the guts to complete this and publish it here.
Thanks.
Thanks, thats awesome
Thanks for such nice reply. ![]()
HI
It might be NI websight problem.
I tried to download another document, but it showing same problem to me.
We apologize for the inconvenience. The links should be working now. We had a minor issue with file paths that our team resolved this morning.
Hi AlbertGeven and PrabhakantPatil-
Regards
Claire Reid
Thanks a Lot for fixing it ![]()
Regards
Prabhakant
Please click on like if you like it. ![]()
Your valuable suggestions are always welcome for the improvement.
Prabhakant
Sorry,
Version 1.2 for the serial port test and
Version 1.1 for Hyper Terminal.
