This is the main VI of a front panel template tool. This tool is built from the Get VI Reference Dialog reference architecture, and therefore can be integrated easily into the LabVIEW Tools drop down menu. When run, it allows the user to select a VI in memory or browse to a VI on disk and change all of that VI's front panel indicator and controls.
The controls and indicators can be replaced with internal LabVIEW styles Modern or System, or they can be replaced with custom controls found in a user provided directory.
When pointing this tool to the user provided directory, the UI template tool will find ctl files in that directory and determine their style (numeric, graph, dial, etc...). After determining the style of all the ctl files in the user provided directory, the tool replaces the selected VI's controls and indicators with the appropriate user provided ctl files (Dials with a dial ctl, Graphs with a graph ctl, etc)
If a bgcolor.txt file is found in the user provided directory, this tool will read that file to decide what color to make the front panel. The tool reads the first line of the text file and converts it to a U32 to set the color of the front panel. All colors in LabVIEW are U32s. So if there is a text file named "bgcolor.txt" inside the dir you targeted, and the first line of the text file is "14287087"... then the targeted VI will have its front panel turn pink. This is accomplished with LabVIEW Scripting.
VI with all modern controls converted to internal system style:
A VI converted to a directory of external controls, in this case, the NI.com theme:
