LabVIEW Architects Forum
Meeting Tuesday, May 17, 2016 1) LabVIEW Codegen Engine for Fast, Template-Based Scripting. 2) Property Inspector 2.0
Meeting Topics
  • Topic 1: Using the LabVIEW Codegen Engine for Fast, Template-Based Scripting
  • Duration: 45 minutes + Q&A
  • Description:  The most efficient way to do LabVIEW scripting is to write VIs of the pieces you would use and copy them to the VI of interest. LabVIEW ships with a code generation engine which quickly and efficiently automates this template based scripting. It has been used internally for fifteen years and was exposed to general users in LabVIEW 7.0. It was dramatically improved for LabVIEW 8.6, with major stability and efficiency enhancements, many of which are not easily accessible to external users. If you do any major scripting, you should seriously consider using the LabVIEW codegen engine. Come find out why.
  • Presenters: DFGray
  • Attached is a zip file containing the presentation, code and the pdf that Damien referred to in his presentation.
  • Topic 2: Property Inspector 2.0
  • Description: The Property Inspector is a toolkit available via the LabVIEW Tools Network. Automate VI development by displaying, searching and editing multiple VI properties. Instantly finds and fixes many problems impossible from the LabVIEW project window. Now including VI Analyzer and Quick Drop Scripting.
  • Presenters: Michael Munroe
  • Slides attached to this document
Meeting Logistics
  • Location: Mopac C, 1S13 @ NI headquarters 11500 North MoPac Expressway, Austin TX
  • Date: Tuesday, May 17, 2016
  • Time: 6:00 PM Central Time
  • Duration: ~ 2 hours
  • Format: presentation and group discussion
  • Food: An accurate headcount helps here so please register if you're attending in-person. If you're not an NI employee, please register. NI employees should use internal invitation; if you're not already on the list contact fabiola@delacor.com. If you are attending remotely, there is no need to register, just join us using the Remote Attendance coordinates below!
Remote Attendance
Thanks to Sixclear for sponsoring remote connection. If you can't make it to NI, join the web conference!
  • Join the Screenshare
  • Join the Audio Conference
    • Via VOIP: click the phone icon after joining
    • Via Phone: 415.655.0381 (or international numbers) with access code 836-896-920#
    • Note: use the chat window for questions or comments anytime; we'll reflect them live in the session!
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(10,510 Views)
Can topic 1 be recorded? I have other appointments during the meeting but really want to learn about this!
(9,324 Views)
As usual, we will do our best to record the sessions and post them later at youtube.com/laftracks
However, technical issues can happen and no promises are made
Fab
(9,326 Views)
Sad I'll be in Houston tomorrow during this UGM.
My lil nephew has a very important t-ball game. 🙂
Hope it goes well! With you in spirit... -drew
Drew Pierce | District Manager, Central Texas | National Instruments
(9,326 Views)
No worries, hopefully everything works well with the recording.
We send cheers to your nephew from here
(9,326 Views)
