LabVIEW Automotive Ethernet
SOME/IP Client / Server Examples
@lhoever wrote:
thx for the example. Do you also have a version, that works with IPv6?
Since, did you test IPv6?
Message 21 of 23
(2,765 Views)
Hi Everyone, I know this is an old thread. Just wanted to know if someone has achieved running both client and server from same port? As far I see, there can be only one json file in C:/etc/ folder and it can define either a server or a client at a time.
Certified LabVIEW Architect
System Test Architect
Electrical Engineering
JLR
Message 22 of 23
(2,700 Views)
Excuse me, I have already sent the find message using client require, but cli_ Is IsServiceAvailable or is the return result negative? The actual ECU has already offered to respond to the service. Ask the cli_ What is the basis for judging IsServiceAvailable?
Message 23 of 23
(2,555 Views)
