LabVIEW Channel Wires
Delete "InsertChannelReplicate.llb" to stop crashes when right clicking
Crashing bug discovered. This crash can happen when you right click on things if you have installed the channel plug-ins even if you never use the channel plug-ins (its a bug in the builder VI). The fix:
Go to
     <labview>\resource\plugins\PopupMenus\edit time panel and diagram
and delete the file named
A replacement LLB will be posted when a fix is available. The Known Issues list has been updated.
Message 1 of 1
(4,147 Views)
