LabVIEW Cloud Toolkits
Aws dynamoDB access
Hello All  ,
I am using Labview to test some telematics product  ,   for this purpose i need to have an access to DaynamoDB  ,  i have downloaded the NI Cloud Toolkit AWS   ,   unfortunately   i didn't found what i am looking for on this Toolkit .
I found anther solution based on the cdata driver for daynamoDB https://www.cdata.com/drivers/dynamodb/odbc/?gclid=Cj0KCQjw0pfzBRCOARIsANi0g0tEXIK_56T23ehRvnniP7oKy... , it works  fine but  it is costly  ,  i have to pay every year  400 dollar just to use this feature  .
on the other hand  , there is already a python script which works fine without any extra cost .
Have any experience with this  before  ?  is it possible to use the python script into Labview ?
Thank you
Abdelhak
(5,404 Views)
Hi Abdelhak
I am using labview to call python to get SAS.
You need to install python integration tool kit.
Please let me know if you need any help.
Good luck!
Hong
(5,393 Views)
Thank you for your replay  ,
Have you any example on how to do it  ?   this toolkit is for free ?
Please find the python script that i want to include in my labview program , Thanks for your help .
import boto3
from boto3.dynamodb.conditions import Key, Attr
def ExtractOdometer(pl):
    odpl = pl[158 * 2:158 * 2 + 8]
    aa = int('0x' + odpl, 16) * 5 / 1000
    print(f'Odometerpip is {aa} km')
tcu_id = 'xxxxxx'
payload_type = '09'
odom_date = '2020-02-26'
print(f'Getting data for TCU {tcu_id} on {odom_date}')
dynamodb = boto3.resource('dynamodb')
table = dynamodb.Table('dev_tcu')
condition = Attr('tcuid').eq(tcu_id)
condition = condition & Attr('type').eq(payload_type)
condition = condition & Attr('timestamp').begins_with(odom_date)
response = table.scan(FilterExpression=condition)
foundvalue = False
while (len(response['Items']) == 0):
    if (('LastEvaluatedKey' in response) and (response['LastEvaluatedKey'])):
        response = table.scan(FilterExpression=condition, ExclusiveStartKey=response['LastEvaluatedKey'])
        for i in response['Items']:
            ExtractOdometer(i['payload'])
            foundvalue = True
            break
    else:
        break
if not foundvalue:
    print ('Odometer value not found')
(5,374 Views)
If you're in LabVIEW 2018 or later, you could also try using the Python Node. It's got shipping examples installed here:
[LabVIEW 20xx]\examples\Connectivity\Python
(5,369 Views)
