LabVIEW Cloud Toolkits
Un-executable when built into exe
Hey Peter - the VI "AMZ_S3_APIHLP_New Multipart Upload.vi", or possibly one of its SubVis isn't executable when I build "Put Object from File (Multipart)" into an exe. Had to drill down in the remote debugger to find it. Because it's locked, I can't try to troubleshoot... Any thoughts?
Edit: I should clarify - I'm using LV2013 to build and its seems to normally include dependencies properly. At least it has for all my other state machines. I just tried building just the set credentials and the multipart upload into a little shell vi, then compiled EXE and tried again to make sure... still broken.
(5,635 Views)
Found it. Disconnect type-defs causes this issue.
(5,024 Views)
