LabVIEW Cloud Toolkits
Why are the VIs password protected?
Hello, I downloaded the package using VIPM, and the block diagrams of the important VIs are password protected. Can I get a copy of the VIs without locked block diagrams so I can see what the code is doing?
Richard
(6,495 Views)
Hi Richard,
Sorry for taking so long to reply, but I wanted to check / discuss some things before getting back to you with the final answer.
Instead of posting the VIs with password protection removed, I rather post the password here:
cEvj4vb76QepdVJ8FGlrtc5SIhX6yMb3
Out of curiosity, may I ask why you need to look into the lower-level VIs? I mean you have some issues / bug, or just curiosity, maybe plan to implement some additional features?
Peter
(6,345 Views)
Thanks Peter! I'm looking at using AWS IoT pub/sub over HTTPS. It appears to use a lot of the header info and accces control you implemented in the S3 toolkit, but using Sig4. I would like to use the lower level code as an example to accelerate the development. This will be an open-source project hosted on GitHub.
https://github.com/Indie-Energy/AWS-IoT-RESTful
Thanks again for opening up the code.
Richard
(6,345 Views)
