LabVIEW Code Questions
Command and Control templates missing New>>SubSystem menu item
Templates were updated during beta to reference roboRIO controllers and that unfortunately caused the menu item to stop showing up.
The attached VI can be placed into your LabVIEW for a quick fix. A patch may be released for this, but it will be identical to this fix.
Place the attached VI into C:\Program Files (x86)\National Instruments\LabVIEW 2022\resource\Framework\Providers\FRCSubsystem directory to patch your LabVIEW.
(2,450 Views)
Thanks for posting this. I believe the directory path is C:\Program Files (x86)\National Instruments\LabVIEW 2020\resource\Framework\Providers\FRCSubsystem
since FRC 2023 still runs on LabVIEW 2020
(2,367 Views)
