LabVIEW Code Questions
FRC AXIS SETUP
Alguien sabe que paso con la herramienta de axis setup para frc, ¿La descontinuaron?.
(3,404 Views)
Yes, the Axis camera setup tool was not provided this year because we didn't believe it was commonly used.
If you have the tool from last year, it should work the same. If you don't have it, I attached a zip containing the tool. I think it will need the 2019 runtime, if you still have that installed.
(3,375 Views)
