LabVIEW Code Questions
Problem with 3 accelerometer using python
  • I have struggle with 3 accelerometer(Model 352c33) using with DAQ(NI-9230BNC + cDAQ-917) with this code:
  • import nidaqmx
    import csv
    import time
    import numpy as np
    # Define your accelerometer channel names here
    accelerometer_channels = ["cDAQ1Mod1/ai0", "cDAQ1Mod1/ai1", "cDAQ1Mod1/ai2"]
    # Create a task for analog input for each accelerometer channel
    tasks = []
    for channel in accelerometer_channels:
    task = nidaqmx.Task()
    task.ai_channels.add_ai_voltage_chan(channel)
    # Set the voltage range for each channel (adjust as needed)
    task.ai_channels[-1].ai_max = 5.0 # Set the maximum voltage to +5V
    task.ai_channels[-1].ai_min = -5.0 # Set the minimum voltage to -5V
    tasks.append(task)
    for i in range(30):
    # Start all tasks
    for task in tasks:
    task.start()
    # Read data from all channels
    data = [task.read(number_of_samples_per_channel=10000) for task in tasks]
    # Stop all tasks
    for task in tasks:
    task.stop()
    # Create a time axis
    time_axis = np.arange(len(data[0])) / 10000 # Assuming the same sampling rate for all channels
    # Save data to a CSV file
    csv_file = f"vibration_data{i}.csv"
    with open(csv_file, "w", newline="") as file:
    writer = csv.writer(file)
    writer.writerow(["Time (s)", "Channel 0", "Channel 1", "Channel 2"]) # Write header row
    for t, ch0, ch1, ch2 in zip(time_axis, *data):
    writer.writerow([t, ch0, ch1, ch2])
    # Sleep to wait for the next trial (optional)
    time.sleep(10.0) # Sleep for 10 seconds between trials
    # Close all tasks
    for task in tasks:
    task.close()
  • Before this code i can use 1 accelerometer to detect vibration signal, but when i adjust the code to use 3. It only detect 1, i can’t use 3 together
Message 1 of 1
(2,001 Views)
