LabVIEW Communications System Design Suite
802.11 app Framework VLC communication problem
Hello Marwanjk,
According to the LabVIEW Communications Product Manager here: http://forums.ni.com/t5/LabVIEW-Communications-System/duplicate-terminals/td-p/3188259
We are planning to release LabVIEW Communications 1.1 next week, so I recommend waiting until then and see if we have any throughput enhancements.
Thomas C.
FlexRIO Product Support Engineer
Message 21 of 28
(3,677 Views)
Hello Marwanjk,
Thomas C.
Message 22 of 28
(3,677 Views)
Hello tcp,
please allow me to hook in here: i am using the 802.11 Application Framework with the USRP 2953. I am not able to stream a video with vlc. I have run a vi similar to your UDPTest to isolate the problem and it seems that the problem lies within vlc.
I have vlc 2.1.5 installed.
Firewall turned off.
It seems that vlc is not able to stream to the udp (s. attached log).
I know that this problem probably does not concern the communication suite still i would be happy for any ideas on this matter.
Message 23 of 28
(3,661 Views)
Hello labviewette,
Thanks for running the UDPTest VI and isolating the issue to VLC.
I think that the best thing to do would be to run a loopback test using VLC.  This can be done using a modified version of the streaming.bat file below.  This script has two commands:
start C:\Progra~2\VideoLAN\VLC\vlc.exe anthem.mp4 --sout=#{access=udp{ttl=1},mux=ts,dst=127.0.0.1:12345} :sout-keep --mtu 1316
This starts VLC's UDP output stream.
start C:\Progra~2\VideoLAN\VLC\vlc.exe udp://@:12346
This starts VLC's UDP input stream.
If you notice, the first command choses an MP4 File, anthem.mp4 comes with LabVIEW Communications Design Suite, and selects the output stream format.  The dst=127.0.0.1.12345 is the destination IP and Port.
In the second command, we read all UDP data from a specific local port.
We should try to make the output port and input port match.  This will cause VLC to loopback on itself.  You can open the bat file in any text editor (i.e. Notepad++), change the second command to:
start C:\Progra~2\VideoLAN\VLC\vlc.exe udp://@:12345
Save the bat file and run it. This might yell because it can't find the anthem.mp4 file.  Just make sure that the MP4 file is in the same folder as the streaming.bat file.
Please let me know if this helps.
Thomas C.
Message 24 of 28
(3,649 Views)
Hello again,
the fact that your proposed loopback worked made me rethink what might have gone wrong initially since basically I was not doing much more than:
- vlc streaming to udp
- running a vi that opened the udp socket, read it, and then wrote the data to another port
- streaming out from the output udp to vlc
and my conclusion is that due to improper udp closing at some point I was not able to stream succeessfully.
I am able to stream over 2 stations each running it's own USRP now.
Thanks tcap.
Message 25 of 28
(3,626 Views)
Awesome! Thanks for the update labviewette!
Thomas C.
Message 26 of 28
(3,607 Views)
Hello Marwanjk,
LabVIEW Communications 1.1 is live!  This should allow you to modify the parameters that control throughput more easily.
http://www.ni.com/download/labview-communications-and-system-design-suite-1.1/5635/en/
Thomas C.
Message 27 of 28
(3,560 Views)
Thanks tcap, I'm going to probe the new version.
Message 28 of 28
(3,525 Views)
