LabVIEW Communications System Design Suite
Disable AGC
I am trying to turn off Automatic Gain Control at usrp n210 but i can't.How to disable AGC?
Message 1 of 8
(7,756 Views)
From what I could find, the AGC is part of some daughterboards. What daughterboard are you using?
Thomas C.
FlexRIO Product Support Engineer
Message 2 of 8
(7,718 Views)
I am using SBX daughterboard.
Message 3 of 8
(7,704 Views)
Are you sure that your currently using AGC?
According to https://www.ettus.com/content/files/kb/Selecting_an_RF_Daughterboard.pdf, only the TVRX2 has built in AGC.
Thomas C.
Message 4 of 8
(7,699 Views)
I am trying the removing noise in the sound file.So,I tried turn off the AGC at USRP.How can I solve this problem?
Thank you.
Message 5 of 8
(7,650 Views)
Hello Ozgur,
Can you please show me where it indicates that you are using AGC?
Are you trying to reduce the noise in a signal that you are outputting or a signal that you are loading from a file?
Thomas C.
Message 6 of 8
(7,646 Views)
I am not using the AGC.Just,I wanted to turn off for removing noise.This is my FM Demodulation code.I want to removing noise in this code by using threshold but i can't.Can you help me?
Thank you.
Message 7 of 8
(7,637 Views)
Hello Ozgur,
I am very confused.
I don't think that the N210 with SBX has a built-in AGC, so it is already disabled. If you have found documentation indicating that you are using a AGC, please link the document here.
How are you planning on using a threshold to reduce noise? I recommend confirming that your radio is recording in your signal of interest and using a bandpass filter to isolate the frequency of interest. This will remove most of the noise. Once you have the frequency isolated, you can demodulate the signal.
Thomas C.
Message 8 of 8
(7,612 Views)
