LabVIEW Communications System Design Suite
FPGA compile server reported an internal error
Dear Sir,
I am trying to change PSS sequence in LTE application framework 2.01. Hence, I need to change coefficient vector of FIR compiler in LTE Cross Correlation.gcdl file. No matter what value I put, there is always an error "FPGA compile server reported an internal error" prompted. Please help.
Jameson
(3,078 Views)
OK, I can change coeffieient values with vector option. However, I still have problem loading coefficient values with .coe file. I use radix=10. Will it cause problem? Please help.
(3,035 Views)
