LabVIEW Communications System Design Suite
How can I estimate the original channel value without affecting the RF?
we have one question about implementing svd beamforming using two USRP-2953r (2x2 mimo ofdm close loop).
What method should be used to perform channel estimation to generate a svd beamforming vector using channel values?
Currently, even if the same packet is sent, different channel values are always estimated for each packet.
Also, let me know how we can control two USRP-2953r on one computer.
We would be very grateful if you could help us with these problems.
Thank you.
Message 1 of 1
(2,698 Views)
