LabVIEW Communications System Design Suite
How is it possible to export the graph directly to an image file as .png, .jpeg, etc.. ?
I have LabVIEW communications 1.1, I've tried to right click on the graph (as indicated in NI support guide) but there is not "Export" option. I've attached what I see if I right click on the graph.
(I've also tried from "Captured Data" but I can only export data in CSV file or see the graph more in detail)
 Graph_rclk
(4,380 Views)
Hey Alessio,
Unfortunately there is not currently a way to export directly to an image file from the graph. When you right-click the graph, the only options available will be to "Capture Data". From the captured data ("Data" tab),  you can export to CSV or view your data within the workspace. Your best bet is to either export the CSV data, and manipulate the graph data in another program, or to simple screenshot the views you want from the workspace directly using another program (eg, Windows Snippet, etc). For a good tutorial on data management see File>>Learn>>Programming Basics>>Storing and Managing Data in LabVIEW Communications.
David C
(4,341 Views)
