LabVIEW Communications System Design Suite
In USRP packet data transmission example, how the receiver knows the packets arrangement?
Hi.
I have a quick question. I am using the packet data transmission example. When I explore the sub-generate-packet-array vi, I see that what we send as data includes guard bits, sync bits, header and our data. There is no information that indicates which packet is the first one. So in the receiver side, how it arrange the received packet from the first to the end?
Thanks in advance.
(3,156 Views)
Hi Ferdoon,
I'm not quite sure what you mean by "indicates which packet is the first one? Do you mean which portion of the message is guard bits and sync bits?
(3,118 Views)
