LabVIEW Communications System Design Suite
Intensity graph and property node
I want to have several intensity graphs using the same scale. In LabView I could use the property nodes to extract the scale and assign it, is there some way to to this in Communications System Design Suite 2?
Also, how do I turn the autoscale in the intensity graph back on after adjusting it manually? There is an autoscale button as p[art of the scale legend for the graph... but it does not seem to do anything.
-Henning Idsøe
(3,762 Views)
Hi Henning
Have you read through the information in the following link?
http://www.ni.com/documentation/en/labview-comms/1.0/data/viewing-and-analyzing-data/
There are also a couple of useful links  about intensity graphs as well-
https://forums.ni.com/t5/LabVIEW-News/Changing-the-Color-of-Intensity-Graphs-and-Charts-in-LabVIEW/b...
http://www.ni.com/documentation/en/labview-comms/1.0/ctrl-ref/intensity-graph-control/
I hope this helps!
Sarah
(3,722 Views)
