LabVIEW Communications System Design Suite
LTE Framework Streaming Example with NI7975R and NI 5792 configuration problems
Hello I want to test the LTE Streaming Example with a set up consisting of a USRP and a Flex Rio Card.
There are two components:
1 Laptop and a USRP RIO 2942R  (This works)
2 PXI System with a Flex Rio Card 7975R and a NI5792 adapter module
We want to transmit data from the USRP to the PXI system. We know that NI5792 is only a receiver but we have not another adapter module.
First question is if this configuration works?
Then we got problems with the configuration of the NI5792. You can see attached the error code.
If we run the LTE Framework on the PXI System the " Error -1 occurred at NI579x Wait for Initialization.gvi"
What do we have to change in the Code on the PXI system?
Thanks for your help
(3,188 Views)
Hey ref110,
Since the 5792 only does Rx, it's likely timing out waiting for the TX to initialize (which obviously it cannot do). Per the getting started guide, it looks like only the 5791 is supported with the LTE Application Framework.
Ben C
RF Systems Engineer
(3,111 Views)
