LabVIEW Communications System Design Suite
Lab 5 - double-sideband suppressed carrier lab 5 + USRP
I am currently building lab 5 in introduction to communication lab 5 (see title). I have built what I think is correct but when I run the program, I can't see both carriers. Attached is the gvi. Any help as to why would be appreciated
(3,758 Views)
I understand you've also opened up a SR for this issue and my colleague has provided you with some info regarding this issue. Let me know if the steps you received through the SR helped resolve this issue.
James F.
(3,723 Views)
