LabVIEW Communications System Design Suite
MyRIO, unrecoverable error
Hello NI Forums,
I'm having difficulties connecting a MyRIO to my system. I've installed all the latest versions of Labview, MyRIO and the latest firmware is on the device, but I keep getting a "version mismatch" error. My take is that it has something to do with the fact that trying to correct the mismatch results in an error where the program spits out an unrecoverable error, claiming it has no IP address.
I'm not sure how to fix this, and google came up empty, with the exception of completely wiping the device. I've added a screenshot of the problem in chronological order, and on the bottom a list of all the versions.
Any idea's?
Martin.
(4,060 Views)
Hello Martin,
Seems like you're issue is related to IP configuration.
Is your myRIO connected to a network? The IP 172.22.11.2 is a local IP of myRIO.
If you click on myRIO in the Remote Systems, how does the Network Settings Tab look like?
Looking forward to your reply!
Kind Regards,
-Natalia
(4,026 Views)
Hi GTL_martin,
It looks like the issue you're having is with a MyRIO in LabVIEW, not to be confused with LabVIEW Communications System Design suite, which is a LabVIEW built for Wireless Prototyping and FPGA design.
I'd recommend moving your post over here to get the correct eyes on your post.
Thanks!
BeenCoughin
RF Systems
(4,012 Views)
