LabVIEW Communications System Design Suite
PSK MOD DEMOD IQ sample capture
Hello all,
I am new to Labview. I wanted to capture IQ samples from a signal generated using a standard PSK modem (COTS). We also want to store corresponding demodulated bits using a standard PSK demodulator LABVIEW example.
The IQ samples (oversampling rate = 16) and their corresponding demodulated bits must in synchronization. How to simulate it in LABVIEW. I am using a standard PSK demodulator example.
(902 Views)
@np1989 wrote:
... I wanted to capture IQ samples from a signal  .... How to simulate it in LABVIEW.
Processing real data is not the same as a simulation. Can you be a bit more specific?
(879 Views)
1. I am sending customized data packet (Unique word + data, say 100 bytes)  at an interval of 1 sec to modulator (COTS).
2. Modulator setting (Rf out at = 950MHz, Mod=BPSK, FEC=disable, Datarate=2.4Kbps)
3. Modulator output is connected to NI (COTS) receiver block. (NI setting: LO freq=950MHz, mod=BPSK, NO FEC, sampling rate=9.6Kbps )
4. Now we wish to tap both IQ samples and their corresponding bits of received data (which should match to original data)
How to design a system in LabVIEW (includes Demodulator block)? Currently I am using a standard PSK demodulator example.
(857 Views)
