LabVIEW Communications System Design Suite
Probes don't show any value
I work with the Communication Design Suite and the 802.11 Framework. I am trying to get some data from the FPGA to the host with FIFOs. My problem is, that the FPGA part doesn't seem to operate, as the Probes I put there all say "Not Executed", no matter where I placed them. But I receive the standard signals, that the Frameworks is able to send. So, can't I probe on FPGA (and in that case, how am I supposed to debug my code) or am I doing something wrong?
(3,097 Views)
Hej DIDS,
Do you simulate the FPGA Code, or actually run it on the FPGA?
And if you simulate, how?
(2,939 Views)
