LabVIEW Communications System Design Suite
Read data from 2 USB ports
Would you kindly help me on this.. I'm not sure if this kind of communication from 2 usb port is possible. I'm trying to get data from 2 USB ports that are from arduino uno board and Phidget interface kit. But whenever i run the program, only one of the data that's coming out. When I select visa serial port for arduino, value from arduino is appear but not from phidget as they does not have vi to select usb port. Image attached.
Thank you.
(3,186 Views)
Hey Aidasaufi,
This forum is meant for users programming with LabVIEW Communications System Design Suite.
For your system I highly recommend moving to LINX to program your Arduino. I also think you should move this discussion to LabVIEW MakerHub. The forum members there are more familiar with using LabVIEW with "Maker" devices.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(3,133 Views)
